[QGIS-trac] [Quantum GIS] #2707: Corruption of national characters
in attribute columns when inserting/editing object in PostGIS
Quantum GIS
qgis at qgis.org
Wed May 12 16:37:59 EDT 2010
#2707: Corruption of national characters in attribute columns when
Reporter: imincik1 | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.5.0
Component: Digitising | Version: HEAD
Keywords: postgis | Platform_version:
Platform: Debian | Must_fix: Yes
Status_info: 0 |
There is corruption of attribute data containing national characters when
creating or editing new objects in PostGIS. The problem every time occurs
after some objects are successfully inserted. I can not figure out exact
operation causing this issue.
Here is example how can I reproduce problem:
1. I have following spatial table:
CREATE TABLE gis.rrr
gid serial NOT NULL,
test character varying(80),
the_geom geometry,
CONSTRAINT rrr_pkey PRIMARY KEY (gid),
CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
'MULTIPOLYGON'::text OR the_geom IS NULL),
CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = (-1))
2. Table is empty before this test. 'ľšč' are slovak national characters.
I will try to do following operations:
- start editing; create one object and insert 'ľšč' in to column 'test';
save
save
save
save
- start editing; create some more objects and insert 'ľšč' in to column
'test'; save
'test'; save
- identify attributes of some features
'test'; save
somewhere here I will see in the log and also in attribute table that I
have something like 'ľšÄťžý' instead of 'ľšč' in column 'text'.
I see this problem for longer time with multiple versions. 1.3 - trunk,
tested on multiple Debian Lenny systems.
Current test was made using this software:
QGIS: 13321M
OS: Debian Lenny
PostGIS: POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
2007" USE_STATS
database encoding: UTF-8
locales: tested with en_US, sk_SK
PostGIS log is attached.
Ivan
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2707>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
