[QGIS-trac] [Quantum GIS] #2727: Legend item labels broken in
composer
Quantum GIS
qgis at qgis.org
Tue May 18 00:13:15 EDT 2010
#2727: Legend item labels broken in composer
Reporter: jctull | Owner: mhugent
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: Printing | Version: HEAD
Keywords: composer legend label item | Platform_version: 10.6.3
Platform: OS X | Must_fix: Yes
Status_info: 0 |
I used to be able to edit a legend item, removing the label from the item,
then adding a label to the sub-item under the arrow widget. This would
place the label next to the symbol rather than above it, allowing you to
nicely compact the legend and make it look neater.
Now, this is not working. Instead, the legend item is blank if you place
the label in the sub-item.
Request: it would also be nice to have a means to quickly swap the label
from the main item to the sub-item to avoid a lot of copying and pasting
work. Perhaps there can be a preference to set a default behavior?
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2727>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
