[QGIS-trac] Re: [Quantum GIS] #2159: Page Setup menu item for Mac
os printing
Quantum GIS
qgis at qgis.org
Tue May 18 13:56:13 EDT 2010
#2159: Page Setup menu item for Mac os printing
Reporter: vrgsmm01 | Owner: ctimko
Type: enhancement | Status: assigned
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: GUI | Version: HEAD
Resolution: | Keywords: printing
Platform_version: | Platform: OS X
Must_fix: No | Status_info: 0
Changes (by ctimko):
* owner: nobody => ctimko
* status: new => assigned
Comment:
"When you try to print from the composer...if the layout paper is bigger
than A4
...print result is out of range.
This problem can be fixed by adding an additional menu idem "page setup"
in macos version otherwise can't print layouts in plotter...because page
setup doesn't work properly.
In version 0.74 the page setup is working perfectly...because if the
composer map paper is different from the printing paper...the "page setup
dialog" is appearing asking you to choose the appropriate page and printer
for printing!
Now...in current version 1.4 this feature is not present...why???" ~ #2425
Patch ready for this as well.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2159#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
