[QGIS-trac] Re: [Quantum GIS] #2733: fTools Add geometry column
fails to add XCOORD if source is GPX file
Quantum GIS
qgis at qgis.org
Thu May 27 18:55:18 EDT 2010
#2733: fTools Add geometry column fails to add XCOORD if source is GPX file
Reporter: marisn | Owner: cfarmer
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: Python plugins and bindings | Version: HEAD
Resolution: | Keywords: ftools
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Changes (by lutra):
* platform: Gentoo => All
Comment:
I noticed that if you open the GPX file trough the standard "add vector"
interface things are pretty different: the attribute table is different
and the "Export/add geometry column" works fine. So it should not be a
ftools problem after all, but a problem of QGIS GPS tools toolbox.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2733#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
