[QGIS-trac] Re: [Quantum GIS] #3126: Sliver holes remain after
dissolve
Quantum GIS
qgis at qgis.org
Mon Nov 1 07:56:44 EDT 2010
#3126: Sliver holes remain after dissolve
Reporter: gislab | Owner: jef
Type: bug | Status: closed
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Vectors | Version: Trunk
Resolution: invalid | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Changes (by lutra):
* cc: cfarmer (added)
* platform: Windows => All
* status: reopened => closed
* resolution: => invalid
* version: => Trunk
Comment:
Hi gislab,
here the following.
[[BR]]
The vector "1.zip" is topologically unclean, no way you can change/correct
this in QGIS right now. It would be nice to have a tool for it, this is
because I'll add to this ticket Carson, and eventually (if you agree) we
can change the summary and the description to something such "add a tool
to correct topology". I would suggest to open a new ticket, '''but if you
feel I'm wrong just reopen this one'''.
The situation is the following:
AFAIK dissolve is made by GEOS and at least by default it '''does
nothing''' (while dissolving) to correct problems like slivers/overlapping
areas. So in any case is NOT a QGIS problem.
You say that the same operation under Arc* gives you a clean vector, so it
would be very interesting if you can attach the vector obtained trough the
dissolve with arc* to give it a look.
One more time: you vector is unclean and nor GEOS nor QGIS can do a lot
for this (QGIS for sure, GEOS probably not). Actually this is the typical
case we use to show how to clean vectors by using GRASS.
[[BR]]
Import the vector in GRASS, take the "1_polygon" layer (the one with the
correct polygons) and then apply the '''v.clean''' module with the
"'''rmarea'''" option. This way it will eliminate all the slivers.
And actually this will work just fine with the vectors you posted, without
having to leave QGIS, just use the GRASS plugin.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3126#comment:10>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
