[QGIS-trac] Re: [Quantum GIS] #3126: Sliver holes remain after
dissolve
Quantum GIS
qgis at qgis.org
Mon Nov 1 12:24:36 EDT 2010
#3126: Sliver holes remain after dissolve
Reporter: gislab | Owner: jef
Type: bug | Status: closed
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Vectors | Version: Trunk
Resolution: invalid | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Comment(by lutra):
Nevertheless I agree that at least QGIS should warn that the attached
polygon (1.zip) does have geometry errors. Actually if you toggle editing
and select the nodes with the node tool it tells (in the lower left
corner) "0 geometry error(s) found".
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3126#comment:11>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
