[QGIS-trac] Re: [Quantum GIS] #3184: Strange behavior of dissolve tool
Quantum GIS qgis at qgis.org
Mon Nov 8 18:57:24 EST 2010
        Reporter:  dr                                |         Owner:  cfarmer
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.6.0
       Component:  MapCanvas                         |       Version:  Trunk
      Resolution:  duplicate                         |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  Yes                               |   Status_info:  0
Changes (by cfarmer):
  * status:  new => closed
  * resolution:  => duplicate
Comment:
 This is really a duplicate of #3126, and appears to boil down to the
 precision of the layers, rather than an actual problem with the dissolve
 tool. Unlike Arc*, QGIS (and GEOS) do not use any tolerance when unioning
 geometries (which is what the dissolve tool uses). As such, layers with
 'nearly' identical geometries will not be dissolved as if they were
 identical. A solution to this is to use the simplify tool beforehand, or
 to reduce the precision of your vector layers.
 I am going to close this one as duplicate.
 Carson
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3184#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
