[QGIS-trac] Re: [Quantum GIS] #2965: error message initializing Qgis 1.5.0
Quantum GIS qgis at qgis.org
Tue Nov 9 03:26:34 EST 2010
        Reporter:  mazariol                          |         Owner:  nobody
            Type:  bug                               |        Status:  reopened
        Priority:  major: does not work as expected  |     Milestone:  Version 1.6.0
       Component:  Build/Install                     |       Version:  1.5.0
      Resolution:                                    |      Keywords:
Platform_version:  Windows                           |      Platform:  Windows
        Must_fix:  Yes                               |   Status_info:  0
Changes (by lutra):
 * cc: jef (added)
  * priority:  critical: causes crash or data corruption => major: does not
               work as expected
Comment:
 No, the problem is not Windows nor QGIS, the problem are the applications
 that do place around copies of the QtCore?4.dll library.
 In Portugal you'll get this error if you install the application "cartão
 do cidadão", a program that let you use (trough a usb sim card reader)
 your digital signature.
 I don't know if there is any way to handle this situations qgis side, let
 see what the devs say, meanwhile remove the program that may have
 installed this library and you'll get QGIS starting.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2965#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
