[QGIS-trac] Re: [Quantum GIS] #3199: incorrect reprojection -
gdalwarp
Quantum GIS
qgis at qgis.org
Fri Nov 12 07:17:15 EST 2010
#3199: incorrect reprojection - gdalwarp
Reporter: martel | Owner: nobody
Type: bug | Status: closed
Priority: major: does not work as expected | Milestone:
Component: Rasters | Version: 1.5.0
Resolution: invalid | Keywords:
Platform_version: | Platform: Windows
Must_fix: No | Status_info: 0
Changes (by martel):
* status: new => closed
* resolution: => invalid
Comment:
Replying to [comment:1 lutra]:
> is this a gdaltools (plugin) problem or a problem of the gdalwarp
utility?
> please check it by running your operation manually, if you get the same
results than close this ticket and report it in the gdal trac.
It seems to be a gdalwarp problem. Older versions of GDAL libraries
included for example in FWTools 1.3.5 produces correct results.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3199#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
