[QGIS-trac] [Quantum GIS] #3203: GRASS toolbox: don't check for
optional parameters
Quantum GIS
qgis at qgis.org
Sat Nov 13 07:50:29 EST 2010
#3203: GRASS toolbox: don't check for optional parameters
Reporter: msieczka | Owner: rugginoso
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: GRASS | Version: Trunk
Keywords: | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
GRASS toolbox should not check if a parameter which is optional is set.
Case: r.cost supports various optional stopping points input. A vector map
is one of them. However, if the a following line is added to it's qgm
file:
<option key="stop_points" hidden="no" advanced="yes"/>
running the module throws an "Exception: Vector map <@PERMANENT> not
found", although the command would run fine without stop_points specified.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3203>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
