[QGIS-trac] [Quantum GIS] #3204: GRASS toolbox: let force an optional flag required
Quantum GIS qgis at qgis.org
Sat Nov 13 08:03:08 EST 2010
   Reporter:  msieczka                          |              Owner:  rugginoso
       Type:  enhancement                       |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  GRASS                             |            Version:  Trunk
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
 It would be nice to be able to enforce an optional parameter in qgm as
 obligatory - sth like a "require=yes" atribute.
 Case: r.cost supports various input types - x,y coords, vector map, raster
 map. According to GRASS toolbox convention, I guess it should be divided
 into 3 seperate ones qgms: r.cost.coord, r.cost.vect, r.cost.rast.
 Although in each case the respective input starting points method should
 be required, there is no way to specify this in a qgm currently.
 #3203 is related - maybe to workaround that bug add support for sth like
 "require=no" BTW?
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3204>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
