[QGIS-trac] Re: [Quantum GIS] #3244: AddGeometry- faulty units and
precision
Quantum GIS
qgis at qgis.org
Tue Nov 23 18:21:37 EST 2010
#3244: AddGeometry- faulty units and precision
Reporter: muscatelle | Owner: nobody
Type: bug | Status: closed
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: Build/Install | Version: 1.5.0
Resolution: invalid | Keywords: ADD Geometry units precision
Platform_version: Ubuntu 10.04 | Platform: Debian
Must_fix: No | Status_info: 0
Changes (by cfarmer):
* status: new => closed
* resolution: => invalid
Comment:
The attached shapefile is not in a projected coordinate system, so
measuring area and perimeter does not really make sense. As mentioned in
the forum thread linked to this ticket, you will need to reproject your
data to a projected coordinate system that supports measuring areas. This
tool does not use the project CRS, and for good reason: it outputs the
area and perimeter as attributes of a layer, so while the project
properties may vary from project to project, the layer itself does not.
I am going to close this as 'invalid'. If you feel that this should not be
the case, please feel free to reopen the ticket.
Carson
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3244#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
