[QGIS-trac] [Quantum GIS] #3255: Access composer items in Python
causes segfault
Quantum GIS
qgis at qgis.org
Thu Nov 25 05:42:44 EST 2010
#3255: Access composer items in Python causes segfault
Reporter: NathanW | Owner: borysiasty
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.7.0
Component: Python plugins and bindings | Version: Trunk
Keywords: composer | Platform_version:
Platform: All | Must_fix: Yes
Status_info: 0 |
If you try and access composer items that were created using the tools in
the composer window, eg new label, scale etc QGIS crashes with a seg
fault.
'''To reproduce:'''
Open composer and create label, select label, open python window and type:
comp = qgis.utils.iface.activeComposers()[0}.composition()
label = comp.selectedComposerItems()[0]
label.displayText() // or any other method
If the label is created using python then the above works as expected,
otherwise QGIS gives a segfault.
This happens if you try and access any type of composer item in python
using the above method.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3255>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
