[QGIS-trac] Re: [Quantum GIS] #2436: New symbology print issue
Quantum GIS
qgis at qgis.org
Fri Oct 1 03:21:37 EDT 2010
Reporter: dr | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Printing | Version: Trunk
Keywords: print, new symbology | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
Comment(by zanollim):
To simply reproduce this bug (1.6.0 trunk), try this:
* open a simple polygon layer
* use ''funny_fill'' to render it (note that the fill pattern is in
''pixel'' and NOT in ''map units'', because if I zoom in/out, the squares
of the pattern are redrawn in the map ALWAYS with the same size)
* now open the print composer, choose for example A4 size and
* export to PDF (or directly print) with option ''Print as raster''
CHECKED
UNCHECKED
* note that both pdf documents are wrong and do not represent the
original map shown in the print composer (the squares of funny fill are
bigger or smaller than the expected result)
I think that this is a critical bug for printing
michele
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2436#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
