[QGIS-trac] Re: [Quantum GIS] #3058: print composer: exporting to
PDF does not
resize correctly vectors if symbology is in mm. Works fine if
units are map units.
Quantum GIS
qgis at qgis.org
Sat Oct 2 08:55:44 EDT 2010
#3058: print composer: exporting to PDF does not resize correctly vectors if
symbology is in mm. Works fine if units are map units.
Reporter: lutra | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Printing | Version: Trunk
Keywords: | Platform_version:
Platform: All | Must_fix: Yes
Status_info: 0 |
Comment(by mhugent):
Do you mean it does not scale the same relatively to the background map?
That's because if you specify the size as e.g. 10 mm, it will be 10mm on
screen and 10mm in printout.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3058#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
