[QGIS-trac] Re: [Quantum GIS] #3058: print composer: exporting to
PDF does not
resize correctly vectors if symbology is in mm. Works fine if
units are map units.
Quantum GIS
qgis at qgis.org
Sun Oct 3 19:22:10 EDT 2010
#3058: print composer: exporting to PDF does not resize correctly vectors if
symbology is in mm. Works fine if units are map units.
Reporter: lutra | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Printing | Version: Trunk
Keywords: | Platform_version:
Platform: All | Must_fix: Yes
Status_info: 0 |
Comment(by lutra):
I'm using the new symbology. If I set a point as a circle symbol with 15mm
of diameter, on screen (in the canvas and in the composer) I can measure
11m, then on paper (printing as PDF) I can measure 14mm.
In general there is a 1mm difference between what was set in the symbology
properties and the paper. For my uses it is ok, maybe for others it is
not.
On screen the measure doesn't seems to be the same as the one set in the
symbology properties (20mm become 14.5mm, 50mm become 37mm, etc.).
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3058#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
