[QGIS-trac] Re: [Quantum GIS] #3078: Scotese's shapefiles causes
Tethys to crash
Quantum GIS
qgis at qgis.org
Mon Oct 4 04:43:36 EDT 2010
#3078: Scotese's shapefiles causes Tethys to crash
Reporter: asierra | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.6.0
Component: Build/Install | Version: 1.5.0
Keywords: | Platform_version:
Platform: OS X | Must_fix: No
Status_info: 0 |
Description changed by jef:
Old description:
> Qgis 1.5.0 crashes everytime I try to load a shapefile from the Earth
> System History GIS collection from C. R. Scotese (
> http://www.scotese.com/ ). The same files loaded fine with previous
> versions of Qgis. If necessary I can send sample shape files to
> developers. Below is a report from console:
> Process: Qgis [7247]
> Path: /Applications/Qgis.app/Contents/MacOS/Qgis
> Identifier: org.qgis.qgis
> Version: 1.5.0 (1.5.0-Tethys)
> Code Type: X86-64 (Native)
> Parent Process: launchd [179]
> Date/Time: 2010-10-02 11:55:50.975 -0500
> OS Version: Mac OS X 10.6.4 (10F569)
> Report Version: 6
> Interval Since Last Report: 5359794 sec
> Crashes Since Last Report: 33
> Per-App Interval Since Last Report: 33988 sec
> Per-App Crashes Since Last Report: 3
> Anonymous UUID: 8E6277AC-C630-44E0-BFB0-88A9D2DAB8F3
> Exception Type: EXC_BAD_ACCESS (SIGSEGV)
> Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000048
> Crashed Thread: 0 Dispatch queue: com.apple.main-thread
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Python support
> ENABLED :-)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : fTools
> (package: fTools)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : GdalTools
> (package: GdalTools)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : MapServer
> Export (package: mapserver_export)
> /Applications/Qgis.app/Contents/MacOS/../Resources/python/osgeo/gdal.py:80:
> DeprecationWarning: gdalconst.py was placed in a namespace, it is now
> available as osgeo.gdalconst
> DeprecationWarning)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : Plugin
> Installer (package: plugin_installer)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : 1-Band
> Raster Colour Table (package: bcccoltbl)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : Colour
> Scale Bar (package: bccscbar)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : Shapefile
> Viewer (package: bccSHPV)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : Freehand
> editing (package: freehandEditing)
> Geoprocessing (package: geoprocessing)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : Improved
> Polygon Capturing (package: improvedpolygoncapturing)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : Numerical
> Vertex Edit (package: numericalVertexEdit)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : Profile
> (package: profiletool)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : qgsAffine
> (package: qgsAffine)
> Rectangles (package: rectangles)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : RGB
> Composition Plugin (package: rgb)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : DEM
> relief shader (package: shadedrelief)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : Split
> Feature (package: splitfeature)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : Table
> Manager (package: tablemanager)
> TopoColour (package: topocolour)
> 10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : Value
> Tool (package: valuetool)
> 10/2/10 11:57:17 AM com.apple.launchd.peruser.501[179]
> ([0x0-0x201201].org.qgis.qgis[7264]) Job appears to have crashed:
> Segmentation fault
New description:
System History GIS collection from C. R. Scotese ( http://www.scotese.com/
). The same files loaded fine with previous versions of Qgis. If necessary
I can send sample shape files to developers. Below is a report from
console:
Report Version: 6
ENABLED :-)
(package: fTools)
10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] DeprecationWarning)
10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : Rectangles
10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : DEM relief
10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : TopoColour
10/2/10 11:57:16 AM [0x0-0x201201].org.qgis.qgis[7264] Loaded : Value Tool
Segmentation fault
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3078#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
