[QGIS-trac] [Quantum GIS] #3081: On-the-Fly-projection crashes QGIS, but not in Windows
Quantum GIS qgis at qgis.org
Mon Oct 4 19:31:32 EDT 2010
   Reporter:  volter                                     |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.6.0
  Component:  Projection Support                         |            Version:  Trunk
   Keywords:                                             |   Platform_version:
   Platform:  Fedora                                     |           Must_fix:  No
Status_info:  0                                          |
 How to reproduce:
  - Download this 0.7 MB shapefile: http://geocommons.com/overlays/5603.zip
  - Open the shapefile and set up EPSG 3416 for On-the-fly (other systems
 also work)
  - Zoom out as long as you can
  - QGIS crashes at a certain level (obviously depending on the coordinate
 system; might be quite early)
 The funny thing is, it doesn't happen in Windows.
 That might help as well:
 Debug: QGIS(21307)/ KSycocaPrivate::openDatabase: Trying to open ksycoca
 from  "/var/tmp/kdecache-volker/ksycoca4"
 Fatal: ASSERT: "std::abs( r_d ) > SMALL_NUM && std::abs( r_n ) >
 SMALL_NUM" in file
 /home/makerpm/rpmbuild/BUILD/qgis-1.6.0/src/core/qgsclipper.h, line 270
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3081>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
