[QGIS-trac] Re: [Quantum GIS] #2786: Live GPS tracking: add support
for garmin USB devices
Quantum GIS
qgis at qgis.org
Tue Oct 5 16:12:42 EDT 2010
#2786: Live GPS tracking: add support for garmin USB devices
Reporter: dr | Owner: mhugent
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: C++ Plugins | Version: Trunk
Keywords: gps,tracking | Platform_version:
Platform: All | Must_fix: No
Status_info: 1 |
Comment(by lutra):
> Getting the hcx to work with ''GPSD'' was relatively easy. Loading the
{{{garmin_gps}}} kernel module with {{{modprobe}}} created a
{{{/dev/ttyUSB}}}''n'', which could be accessed with ''gpsd''. Both
''xgps'' and ''qgis'' could in turn access ''gpsd'' on host
{{{localhost}}} on port {{{2947}}}.
ok, got it finally. Thanks a lot for the hint.
Just one question: I cannot see any info about the position of the
satellites and the intensity of the signal. Is this supposed to work or it
will not work in any case with Garmins?
> The ''gps tools'' also only interfaces with {{{gpsbabel}}} and doesn't
directly access any GPS devices. I don't think we should duplicate the
efforts of ''GPSD'' and/or ''gpsbabel''.
Well depends. See above. If the lack of info about signal and sat position
is because of Garmin units then forget about it. If with gpsbabel this
features will work then maybe will be worth the effort.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2786#comment:21>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
