[QGIS-trac] [Quantum GIS] #3092: Gdal Tools Warp tool fails to read
extents
Quantum GIS
qgis at qgis.org
Fri Oct 8 03:16:32 EDT 2010
#3092: Gdal Tools Warp tool fails to read extents
Reporter: sowelu | Owner: borysiasty
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Python plugins and bindings | Version: Trunk
Keywords: | Platform_version: Kubuntu 10.04
Platform: Debian | Must_fix: No
Status_info: 0 |
Using GDAL Tools, Warp tool I was getting a Python message that an index
was out of range. The problem was in this code in doMerge.py where
indicated
info = QString( arr ).split( "\n" )
ulCoord = info[ info.indexOf( QRegExp( "^Upper\sLeft.*" ) )
].simplified()
lrCoord = info[ info.indexOf( QRegExp( "^Lower\sRight.*" ) )
].simplified()
ul = ulCoord.split( " " )
lr = lrCoord.split( " " )
xUL = ul[ 3 ].replace( ",", "" ).toDouble() [ 0 ] <--- Index error
yUL = ul[ 4 ].replace( ")", "" ).toDouble()[ 0 ]
xLR = lr[ 3 ].replace( ",", "" ).toDouble()[ 0 ]
yLR = lr[ 4 ].replace( ")", "" ).toDouble()[ 0 ]
This resulted from a raster with the following partial gdalinfo
Upper Left (13631210.192,-3336272.678)
Lower Left (13631210.192,-3348502.603)
Upper Right (13643440.117,-3336272.678)
Lower Right (13643440.117,-3348502.603)
Center (13637325.154,-3342387.640)
It appears as though the ulCoord string is not being split properly on
spaces, because the spaces do not exist around the comma and bracket. I am
compiling QGIS with GDAL trunk (on Linux), so maybe the format has
changed.
The code below fixed the problem and might be more robust (although I am
not very good at python).
].simplified()
].simplified()
xUL = ulCoord[ulCoord.indexOf( "(" ) + 1 : ulCoord.indexOf( "," ) -
1].toDouble()[0]
yUL = ulCoord[ulCoord.indexOf( "," ) + 1 : ulCoord.indexOf( ")" ) -
1].toDouble()[0]
xLR = lrCoord[lrCoord.indexOf( "(" ) + 1 : lrCoord.indexOf( "," ) -
1].toDouble()[0]
yLR = lrCoord[lrCoord.indexOf( "," ) + 1 : lrCoord.indexOf( ")" ) -
1].toDouble()[0]
Roland
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3092>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
