[QGIS-trac] Re: [Quantum GIS] #62: Qgis only supports postgres keys
of type int
Quantum GIS
qgis at qgis.org
Mon Oct 11 18:48:10 EDT 2010
#62: Qgis only supports postgres keys of type int
Reporter: g_j_m | Owner: jef
Type: patch | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Data Provider | Version: Trunk
Keywords: | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
Comment(by jef):
Replying to [comment:17 willfurnass]:
> It would also be nice if PostGIS sequences could be used for layer keys.
They already can. If the primary key is for instance {{{SERIAL}}}, the
default value is a {{{nextval()}}} call, which QGIS evaluates on
{{{INSERT}}}.
> I frequently wish to view the result of applying PostGIS aggregate
functions using QGIS but this can't be done using relational views as the
results of such queries lack anything that could be used as a primary key;
I therefore end up littering my db with temporary tables created using
'SELECT...INTO...' so as to view the results of aggregate queries in QGIS.
Allowing a self-incrementing sequence col within a view to be used as a
layer key would be a (slightly ugly) way around this.
The feature ids are necessary to identify which feature is to be deleted
or updated. The table/view is not only queried once, but eg. for each
render operation with the current extent in the where clause. And in
every query each feature is supposed to have the same id as in the
previous queries. I'm not sure how that should work with sequences in
views.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/62#comment:18>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
