[QGIS-trac] [Quantum GIS] #3111: filtering of shapefile with query
builder not working when using 'excluding' query
Quantum GIS
qgis at qgis.org
Thu Oct 14 00:35:26 EDT 2010
#3111: filtering of shapefile with query builder not working when using
'excluding' query
Reporter: nirvn | Owner: jef
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Vectors | Version:
Keywords: | Platform_version:
Platform: All | Must_fix: Yes
Status_info: 0 |
Let's say you have 4 polygons in a shapefile
| id | name |
| 0 | polygon-a |
| 1 | polygon-b |
| 2 | polygon-c |
| 3 | polygon-d |
If you filter the shapefile using this query:
id = 1 AND id = 2 AND id = 3
QGIS will properly display only the polygons with id 1, 2 and 3.
However, if you filter the shapefile using this query:
id != 0
QGIS will fail to eliminate polygon with id 0.
The problem started to occur 2 days ago.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3111>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
