[QGIS-trac] Re: [Quantum GIS] #3111: filtering of shapefile with
query builder not working when using 'excluding' query
Quantum GIS
qgis at qgis.org
Thu Oct 14 03:06:58 EDT 2010
#3111: filtering of shapefile with query builder not working when using
'excluding' query
Reporter: nirvn | Owner: jef
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Vectors | Version:
Keywords: | Platform_version:
Platform: All | Must_fix: Yes
Status_info: 0 |
Old description:
> Let's say you have 4 polygons in a shapefile
> | id | name |
> | 0 | polygon-a |
> | 1 | polygon-b |
> | 2 | polygon-c |
> | 3 | polygon-d |
> If you filter the shapefile using this query:
> id = 1 AND id = 2 AND id = 3
> QGIS will properly display only the polygons with id 1, 2 and 3.
> However, if you filter the shapefile using this query:
> id != 0
> QGIS will fail to eliminate polygon with id 0.
> The problem started to occur 2 days ago.
New description:
|| id || name ||
|| 0 || polygon-a ||
|| 1 || polygon-b ||
|| 2 || polygon-c ||
|| 3 || polygon-d ||
id != 0
Comment(by jef):
Please include a shapefile and report the OGR version you are using.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3111#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
