[QGIS-trac] Re: [Quantum GIS] #62: Qgis only supports postgres keys
of type int
Quantum GIS
qgis at qgis.org
Thu Oct 14 06:20:59 EDT 2010
#62: Qgis only supports postgres keys of type int
Reporter: g_j_m | Owner: jef
Type: patch | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Data Provider | Version: Trunk
Keywords: | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
Comment(by willfurnass):
> The feature ids are necessary to identify which feature is to be deleted
or updated. The table/view is not only queried once, but eg. for each
render operation with the current extent in the where clause. And in
every query each feature is supposed to have the same id as in the
previous queries. I'm not sure how that should work with sequences in
views.
Interestingly both of the following views can be loaded by uDig.
CREATE VIEW myview AS ( SELECT zone_ref,
ST_ConvexHull(ST_Collect(wkb_geometry)) FROM table_of_points GROUP BY
zone_ref);
CREATE VIEW myview_with_id AS ( SELECT nextval('some_seq'), zone_ref,
zone_ref);
Does anyone know how uDig internally handles the rendering and
manipulation of tables/views lacking a UNIQUE constraint? Would it be
possible to allow for the viewing of such relations in some sort of read-
only mode? Apologies if I'm missing something obvious here.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/62#comment:19>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
