[QGIS-trac] Re: [Quantum GIS] #3099: Projection Failure
Quantum GIS
qgis at qgis.org
Thu Oct 14 07:07:37 EDT 2010
Reporter: badams | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Projection Support | Version:
Keywords: Projection Failure | Platform_version:
Platform: Windows | Must_fix: No
Status_info: 0 |
Comment(by badams):
Hi Lutra,
Sorry for the slow response. Needed to run some trials.
The 1.3m variation between your conversion and mine is acceptable. Ran
some trials with a professional Mapinfo user and we able to get a similar
variation out of Mapinfo depending on the transforms selected so I'm happy
the parameters you have are correct.
As I don't have the understanding, or the time, to implement these changes
myself, I'm going to put some $$$ up for a bug fix. I'll run it past Paolo
Cavallini first but I need a "plug and play" solution. Ideally the results
will become part of QGIS so that anyone working on Australian data will
benefit.
Given you understand the problem, can I ask you to help me put the bug fix
proposal together?
Thanks
Brett
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3099#comment:14>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
