[QGIS-trac] [Quantum GIS] #3118: GdalTools (warp): add support for
ntv2 grid and +towgs84 transformations
Quantum GIS
qgis at qgis.org
Sat Oct 16 06:44:39 EDT 2010
#3118: GdalTools (warp): add support for ntv2 grid and +towgs84 transformations
Reporter: lutra | Owner: brushtyler
Type: enhancement | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Python plugins and bindings | Version: Trunk
Keywords: | Platform_version:
Platform: All | Must_fix: Yes
Status_info: 0 |
Hi Giuseppe, this is the new description for the old ticket available in
the gdal tools tracker.
https://trac.faunalia.it/GdalTools-plugin/ticket/57
Please have a look also to the new description of ticket that describes
the same enhancement request, but for vectors.
https://trac.osgeo.org/qgis/ticket/2913#comment:3
in qgis:
[[BR]]
[[BR]]
*) a new menu to allow a user import ntv2 grids (.gsb files): the same
files need to be copied in the proper system location, for example
"/etc/proj" for linux. The same menu would serve to import grids for
vectors transformation (see #2913).
[[BR]][[BR]]
in the "warp" tool:
*) add a dropdown to let the user choose the appropriate ntv2 grid, among
the ones available in the proper system folder
[[BR]][[BR]]
*) if the user chooses a ntv2 grid the underlying gdalwarp operation MUST
always add the "+wktext" parameter in the source srs definition
[[BR]][[BR]]
always add the "+towgs84=0,0,0" parameter in the target srs definition, if
this srs is a projected one
*) add a field to let the user write manually +towgs84 parameters in case
he/she don't want/need to use ntv2 grids. This field and the ntv2 dropdown
need to be mutually exclusive.
g) make the windows where the command shows, while the users chooses the
options, editable. I know there is already a ticket about this.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3118>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
