[QGIS-trac] Re: [Quantum GIS] #3125: Problems outputing a layout with small labels to PDF
Quantum GIS qgis at qgis.org
Sun Oct 17 05:22:17 EDT 2010
        Reporter:  gislab                            |         Owner:  nobody
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.6.0
       Component:  Build/Install                     |       Version:
      Resolution:  duplicate                         |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Changes (by lutra):
  * status:  new => closed
  * resolution:  => duplicate
Comment:
 This seems to me duplicate of #3058.
 If you set the font units in map units you can get the labels printed
 correctly (see attached file), if you use mm the same labels are rendered
 wrong.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3125#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
