[QGIS-trac] Re: [Quantum GIS] #3124: Add 'Apply' button to the
layer's query function
Quantum GIS
qgis at qgis.org
Sun Oct 17 06:49:38 EDT 2010
#3124: Add 'Apply' button to the layer's query function
Reporter: jrm | Owner: nobody
Type: enhancement | Status: closed
Priority: minor: annoyance | Milestone: Version 1.6.0
Component: GUI | Version:
Resolution: fixed | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Comment(by jrm):
Replying to [comment:3 jef]:
> Sorry, I wasn't able to reproduce that problem. The only problem there
was, was that the sample button used the original query, so to see values
that were excluded by the earlier query, you needed to clear, close and
reopen. Now it's works on the last successfully tested query, so you can
"test" and retrieve the values of the current query.
Thank for the clarification, I tried rv14387 but I did not use the 'test'
button to reset the sample because I didn't understood it was its intended
function. Maybe this should be the role of 'Clear' ?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3124#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
