[QGIS-trac] [Quantum GIS] #3130: Internal SVG resources not
selectable on OS X
Quantum GIS
qgis at qgis.org
Sun Oct 17 10:19:52 EDT 2010
#3130: Internal SVG resources not selectable on OS X
Reporter: kyngchaos | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Symbology | Version: Trunk
Keywords: svg | Platform_version:
Platform: OS X | Must_fix: No
Status_info: 0 |
When asked to choose an SVG file for symbology (one place I ran into this,
there may be others), it's a normal file chooser. On OS X, you cannot
navigate into an application package, so it's not possible to select any
of the builtin SVG files.
One nice solution would be to show a list of builtin SVG to choose from.
Since there are a lot, and organized in subfolders, a menu would be
cumbersome. A list box, hierarchically organized, would be better. Even
better, disclosure triangles to collapse/expand folders. Of course, it
would need an option to choose an external user file.
If that's not possible or practical, I'll have to change the install
process to install the SVG externally in /Library/Application Support (or
similar in a users home). This would then require an installer for
packaging QGIS for distribution (no drag-n-drop install).
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3130>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
