[QGIS-trac] [Quantum GIS] #3134: Coordinate Reference System
Selector dialog box should indicate which layer it is refering to.
Quantum GIS
qgis at qgis.org
Mon Oct 18 19:01:06 EDT 2010
#3134: Coordinate Reference System Selector dialog box should indicate which layer
it is refering to.
Reporter: cgsbob | Owner: nobody
Type: bug | Status: new
Priority: minor: annoyance | Milestone: Version 1.6.0
Component: Projection Support | Version:
Keywords: | Platform_version:
Platform: Debian | Must_fix: No
Status_info: 0 |
If you have set up qgis to "Prompt for CRS" when the CRS is unknown to
qgis and you select several files, you will be greeted with the
"Coordinate Reference System Selector" dialog box for each of these files.
Since this dialog box does not tell you which file it is referring to or
give you an opportunity to look at the files metadata, you are left
guessing.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3134>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
