[QGIS-trac] [Quantum GIS] #3136: Update NZ projections for grid
transformation support
Quantum GIS
qgis at qgis.org
Tue Oct 19 19:45:29 EDT 2010
#3136: Update NZ projections for grid transformation support
Reporter: jpalmer | Owner: jef
Type: patch | Status: new
Priority: minor: annoyance | Milestone: Version 1.6.0
Component: Projection Support | Version: Trunk
Keywords: proj4, NZGD2000, NZGD49, grid | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
This SQL update script modifies the srs.db proj4 parameters so that the
NZGD49<->NZGD2000 transformation grid is used. Also in the case when the
grid is not found the lower accuracy 7 parameter transformation is used.
This is a follow on to r14399.
See http://www.linz.govt.nz/geodetic/conversion-coordinates/geodetic-
datum-conversion/nzgd1949-nzgd2000/index.aspx for more information
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3136>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
