[QGIS-trac] Re: [Quantum GIS] #3145: Dash in plugin name causes
unhelpful error message
Quantum GIS
qgis at qgis.org
Fri Oct 22 13:59:06 EDT 2010
#3145: Dash in plugin name causes unhelpful error message
Reporter: rehakv1 | Owner: borysiasty
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Python plugins and bindings | Version: Trunk
Keywords: | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
Comment(by rehakv1):
> You should rename your plugin folder and package to "dash_test" because
the chars after the dash in the package name are used for release name or
version (e.g "dash_test-dev.zip" or "dash_test-1.0.zip").Instead the
folder name must be truncated before the dash (i.e. "dash_test" in both
the above cases).
Yes, I figured this out and renamed my plugin folder. I also removed the
version number based on this observation. Is there any recomendation or
best practice guide for plugin naming? I see that e.g. the plugin in
Faunalia repo don't add version number to the zip file.
> The error message is for users, not for developers. IMHO users don't
want to know why the package is broken.
Sorry, but I don't think this a good reasoning. The error message "The
plugin is broken. Python said: invalid syntax" has no meaning to a regular
user. And the developer has no chance to find out what's wrong with the
plugin. I spent more than hour reviewing my source code because I thought
there was a syntax error in my Python code. If the error was "Invalid
filename" or even better "Invalid filename - allowed characters are
alphanumeric symbols and underscore" I would have fixed it in 5 minutes.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3145#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
