[QGIS-trac] [Quantum GIS] #3154: SVG Patterns: References to SVG
files should
start with pattern/symbol repository when paths are set to relative
Quantum GIS
qgis at qgis.org
Mon Oct 25 11:49:51 EDT 2010
#3154: SVG Patterns: References to SVG files should start with pattern/symbol
Reporter: neumann | Owner: nobody
Type: bug | Status: new
Priority: minor: annoyance | Milestone: Version 1.6.0
Component: Symbology | Version:
Keywords: | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
For SVG pattern fills, currently, the paths are stored relatively to the
project file and not relatively to the symbol/pattern repository.
This makes it harder to move projects to a server or different machine
that may have a different file/path layout.
It would be good if it could be implemented the same way like SVG symbols:
Current relative behavior with symbols:
<pointsymbol>svg:/abwasser/Oelabscheider_Mischwasser.svg</pointsymbol>
Current relative behavior with patterns:
<layer pass="0" class="SVGFill" locked="0" >
<prop k="svgFile"
v="../../qgis/patterns/use_zone_plan/wohnzone_mit_gewerbeerleichterung_1_satz_w2_40_wohnzone_2_geschossig.svg"
<prop k="width" v="20" />
</layer>
I think the "relative" paths should be stored absolutely, but starting
from the pattern/symbol repository, with the svg:/ syntax.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3154>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
