[QGIS-trac] [Quantum GIS] #3156: wms getmap request with unknown
epsg
Quantum GIS
qgis at qgis.org
Tue Oct 26 04:17:31 EDT 2010
#3156: wms getmap request with unknown epsg
Reporter: francesco | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.6.0
Component: Build/Install | Version: 1.5.0
Keywords: wms getMap EPSG | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
Hello all,
we noticed that qgis in not able to build the WMS getMap Request if an
EPSG is not recognized by qgis (meaning that it is not in the tbl_srs
table of the srs.db database).
since the 1.5 version we can easily add the unknown epsg just adding a
record in that table, but you can understand that in not nice to have to
maintain that table manually. For example, in that DB it is not present
the EPSG:102113, that is the Web Mercator (Google) for Esri. Just adding
the record in the tbl_srs table then qgis is able to build the correct
getMap request, including the SRS parameter with the EPSG chosen by the
user. Otherwise it include the CRS:84.
What we can not understand is why for qgis it is not enough to read the
SRS from the capabilities file and let the user to choose the EPSG even
when the EPSG is not in the tbl_srs table.
We have this problem mainly with our customized SRS that is an UTM ED50
with a false northing of -4000000, so we have a WMS with the EPSG:NONE or
EPSG:0, but for correct add the WMS layer in qgis we had to add a record
in the tbl_srs (with this prj: "+proj=tmerc +lat_0=0 +lon_0=9 +k=0.9996
+x_0=500000 +y_0=-4000000 +ellps=intl +units=m +no_defs") and it works. In
this case we have to send the customized srs.db to the user that wish to
visualize our WMS in qgis: really not nice.
For example, the WMS url to check this behaviour is:
http://servizigis.regione.emilia-
romagna.it/arcgis/public_sgss/geocatalogo_mappa/MapServer/WMSServer?
We already noticed this behaviour in the past (2009 March) in the 1589
ticket, but then had no time to follow the development.
Thanks,
francesco
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3156>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
