[QGIS-trac] Re: [Quantum GIS] #3126: Sliver holes remain after
dissolve
Quantum GIS
qgis at qgis.org
Sun Oct 31 13:06:31 EDT 2010
#3126: Sliver holes remain after dissolve
Reporter: gislab | Owner: jef
Type: bug | Status: closed
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Vectors | Version:
Resolution: invalid | Keywords:
Platform_version: | Platform: Windows
Must_fix: No | Status_info: 0
Changes (by lutra):
* status: new => closed
* resolution: => invalid
Comment:
Replying to [comment:4 gislab]:
> I don't have grass.
Ok. Try Install it and import your vector, you'll see that the it is
really unclean in origin, for this reason you cannot expect that the
dissolve tool to fix the slivers (because is not its function), nor you
can expect a clean dissolve of the vector because as is clear, it is not
topologically correct.
After importing it in GRASS you'll have the original vector in 3 layers:
the correct polygons, the slivers/holes, and the overlapping areas.
I'll attach them all to this ticket.
If you want to do a dissolve of your vector you'll have to:
import it in GRASS, apply one or more v.clean modules in order to remove
slivers and then export it.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3126#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
