[QGIS-trac] Re: [Quantum GIS] #3017: Save as shapefile in AGD84 CRS
Quantum GIS
qgis at qgis.org
Fri Sep 17 08:05:35 EDT 2010
Reporter: micha | Owner: jef
Type: bug | Status: closed
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Vectors | Version: 1.5.0
Resolution: worksforme | Keywords: CRS shapefile
Platform_version: Lenny | Platform: Debian
Must_fix: No | Status_info: 0
Comment(by micha):
Replying to [comment:1 jef]:
> Replying to [ticket:3017 micha]:
> > A text file of locations in the AGD84 zone 51 CRS (S. Hemisphere, EPSG
20351) was imported with the delimited text plugin. The this layer was
saved as a shapefile, choosing the AGD84 CRS. This resulted in a "Latitude
or Longitude exceeds limits" error. The global CRS was EPSG:4326.
> > Changing the global CRS to EPSG:20351 does solve the problem and
allows saving as a shapefile with the correct CRS. But I think this
shouldn't occur in any global CRS.
> > (checked both on Linux and Windows)
> I can only reproduce the problem, when I don't actually specify the
right CRS for the delimited text layer (ie. keep it WGS84). "Saving as"
in AGD84 then means reprojecting from WGS84 to AGD84 and that leads to the
PROJ exception as the coordinates are illegal for WGS84.
> When setting the coordinate system of the delimited text layer to AGD84,
saving as AGD84 works fine.
> I don't think this is a bug.
The problem, I think, is the default global CRS. If the user just leaves
the default, then loads a csv file, QGIS *assumes* it is in WGS84, and
there's no place to indicate otherwise. Then when he wants to export to
shape with the correct CRS, it fails. Apparently this behavior of the
default global CRS is not so obvious to users.
Thanks,
Micha
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3017#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
