[QGIS-trac] Re: [Quantum GIS] #2884: crash when resizing vertically
the overview window
Quantum GIS
qgis at qgis.org
Sun Sep 19 12:32:18 EDT 2010
#2884: crash when resizing vertically the overview window
Reporter: lutra | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.6.0
Component: GUI | Version: Trunk
Keywords: | Platform_version:
Platform: Debian | Must_fix: Yes
Status_info: 0 |
Comment(by trapanator):
Confirmed the bug here (Archlinux, QT 4.6.3, KDE 4.5.1). I've compiled
QGIS with debugging options on, here's the backtrace of the segmentation
fault:
Debug: /usr/local/src/qgis_unstable/src/core/qgsmaprenderer.cpp: 224:
(render) ========== Rendering ==========
Warning: QPainter::end: Painter not active, aborted
Debug: /usr/local/src/qgis_unstable/src/gui/qgsmapoverviewcanvas.cpp: 162:
(drawExtentRect) panning: extent to widget: [0,23] [251x129]
Warning: QPixmap::operator=: Cannot assign to pixmap during painting
Debug: /usr/local/src/qgis_unstable/src/core/qgsmaprenderer.cpp: 195:
(adjustExtentToSize) Map units per pixel (x,y) : 5041.32, 4900.5
Debug: /usr/local/src/qgis_unstable/src/core/qgsmaprenderer.cpp: 196:
(adjustExtentToSize) Pixmap dimensions (x,y) : 250, 179
Debug: /usr/local/src/qgis_unstable/src/core/qgsmaprenderer.cpp: 197:
(adjustExtentToSize) Extent dimensions (x,y) : 1.26033e+06, 877190
Debug: /usr/local/src/qgis_unstable/src/core/qgsmaprenderer.cpp: 198:
(adjustExtentToSize) -594174.7892561983317137,-453595.0413223140058108 :
666155.7892561983317137,423595.0413223140058108
Debug: /usr/local/src/qgis_unstable/src/core/qgsscalecalculator.cpp: 139:
(calculateGeographicDistance) Distance across map extent (m): 4.68037e+10
Debug: /usr/local/src/qgis_unstable/src/core/qgsscalecalculator.cpp: 90:
(calculate) Using conversionFactor of 39.3701
Debug: /usr/local/src/qgis_unstable/src/core/qgsmaprenderer.cpp: 209:
(adjustExtentToSize) Scale (assuming meters as map units) = 1:7.07584e+11
Warning: QPainter::begin: A paint device can only be painted by one
painter at a time.
(drawExtentRect) panning: extent to widget: [0,26] [251x128]
(adjustExtentToSize) Map units per pixel (x,y) : 5041.32, 4851.6
(adjustExtentToSize) Pixmap dimensions (x,y) : 250, 186
(adjustExtentToSize) Extent dimensions (x,y) : 1.26033e+06, 902397
(adjustExtentToSize) -594174.7892561983317137,-466198.3471074380213395 :
666155.7892561983317137,436198.3471074380213395
painter at a time.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2884#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
