[QGIS-trac] Re: [Quantum GIS] #2973: Selection tool is not
selecting a complex object
Quantum GIS
qgis at qgis.org
Mon Sep 20 21:35:49 EDT 2010
#2973: Selection tool is not selecting a complex object
Reporter: gislab | Owner: nobody
Type: bug | Status: reopened
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: MapCanvas | Version: Trunk
Resolution: | Keywords:
Platform_version: | Platform: Windows
Must_fix: No | Status_info: 0
Comment(by jpalmer):
I can get it to work for all of the select tools on this dataset.
I suspect the problem dr is having is the selection tools now use contains
rather than intersects by default. Maybe the best solution is to make
intersects the default method for all selection tools. Then provide an
option to change it to contains if the user prefers.
I have made a patch
[https://trac.osgeo.org/qgis/attachment/ticket/2938/select_feature_option.diff
patch] in #2938 that hopefully addresses this issue.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2973#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
