[QGIS-trac] [Quantum GIS] #3032: Diagram overlay and trunk not
building
Quantum GIS
qgis at qgis.org
Tue Sep 21 15:28:17 EDT 2010
#3032: Diagram overlay and trunk not building
Reporter: jctull | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Build/Install | Version: Trunk
Keywords: diagram overlay build | Platform_version: 10.6.4
Platform: OS X | Must_fix: Yes
Status_info: 0 |
The diagram overlay plugin is not compiling at this time in trunk. Here is
the error message:
Scanning dependencies of target diagramoverlay
[ 79%] Building CXX object
src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsdiagramdialog.cpp.o
src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsdiagramcategory.cpp.o
src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsdiagramfactory.cpp.o
src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgswkndiagramfactory.cpp.o
src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgswkndiagramfactorywidget.cpp.o
src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsbardiagramfactory.cpp.o
src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgspiediagramfactory.cpp.o
src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgssvgdiagramfactory.cpp.o
src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgssvgdiagramfactorywidget.cpp.o
src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsdiagramfactorywidget.cpp.o
[ 80%] Building CXX object
src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsdiagramoverlay.cpp.o
src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsdiagramoverlayplugin.cpp.o
src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsdiagramrenderer.cpp.o
/bin/sh: line 1: 69883 Segmentation fault /usr/local/bin/ccache g++
-Ddiagramoverlay_EXPORTS -DQT_SVG_LIB -DQT_WEBKIT_LIB -DQT_GUI_LIB
-DQT_XML_LIB -DQT_SQL_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB
-DQT_NO_CAST_TO_ASCII -DQT_NO_DEBUG -O3 -DNDEBUG -arch x86_64 -fPIC
-F/Library/Frameworks -I/Library/Frameworks/QtSvg.framework/Headers
-I/Library/Frameworks/QtWebKit.framework/Headers
-I/Library/Frameworks/QtGui.framework/Headers
-I/Library/Frameworks/QtXml.framework/Headers
-I/Library/Frameworks/QtSql.framework/Headers
-I/Library/Frameworks/QtNetwork.framework/Headers
-I/Library/Frameworks/QtCore.framework/Headers
-I/Users/jctull/sources/qgis/trunk/build
-I/Users/jctull/sources/qgis/trunk/build/src/plugins/diagram_overlay
-I/Library/Frameworks/GEOS.framework/Headers
-I/Users/jctull/sources/qgis/trunk/src/plugins/diagram_overlay/../../core
-I/Users/jctull/sources/qgis/trunk/src/plugins/diagram_overlay/../../core/pal
-I/Users/jctull/sources/qgis/trunk/src/plugins/diagram_overlay/../../core/raster
-I/Users/jctull/sources/qgis/trunk/src/plugins/diagram_overlay/../../core/renderer
-I/Users/jctull/sources/qgis/trunk/src/plugins/diagram_overlay/../../core/symbology
-I/Users/jctull/sources/qgis/trunk/src/plugins/diagram_overlay/../../gui
-DCORE_EXPORT= -DGUI_EXPORT= -DPYTHON_EXPORT= -DANALYSIS_EXPORT= -o
CMakeFiles/diagramoverlay.dir/qgsdiagramrenderer.cpp.o -c
/Users/jctull/sources/qgis/trunk/src/plugins/diagram_overlay/qgsdiagramrenderer.cpp
make[2]: ***
[src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsdiagramrenderer.cpp.o]
Error 139
make[1]: ***
[src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/all] Error 2
make: *** [all] Error 2
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3032>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
