[QGIS-trac] Re: [Quantum GIS] #2954: Would be useful to be able to
position text away from points
Quantum GIS
qgis at qgis.org
Wed Sep 22 03:37:02 EDT 2010
#2954: Would be useful to be able to position text away from points
Reporter: infobleep | Owner: nobody
Type: enhancement | Status: reopened
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Symbology | Version: 1.5.0
Resolution: | Keywords: position, text, points
Platform_version: XP | Platform: All
Must_fix: No | Status_info: 0
Comment(by lutra):
Do you need to displace labels at wish in the canvas or in the print
(layout) composer?
In any case seems an interesting feature but not really simple to
implement. Consider funding the project to get what you need
http://qgis.org/wiki/Bugs
Replying to [comment:6 infobleep]:
> Do you mean in the form of a field containing the distances? That
wouldn't work because a lot of the text placement changes are none by eye.
It is more of a visual look rather than a data driven look if that makes
sense.
> For example today I was working on a document where I needed to place
number labels on a map. The base map they were appearing on was a raster
image so nothing could be moved in that. In order to avoid text clashes,
and even grid clashes, I manually moved the numbers where possible. This
manual moving was on a case by case basis. I was doing this work in ArcGIS
9.3.1 and that requires one to create an annotations layer, which itself
isn't satisfactory, as you then lose the direct link between the text and
the layer it represents.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2954#comment:7>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
