[QGIS-trac] [Quantum GIS] #3036: save as to shapefile for postgis
layers with tool long column names doens't work
Quantum GIS
qgis at qgis.org
Thu Sep 23 08:19:06 EDT 2010
#3036: save as to shapefile for postgis layers with tool long column names doens't
work
Reporter: cmoe | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Data Provider | Version: Trunk
Keywords: | Platform_version:
Platform: RedHat | Must_fix: Yes
Status_info: 0 |
Save as to shapefile for postgis layers with tool long column names
doens't work.
1. Load a postgis layer with a column that has more then 10 charactes in
its name (e.g. archive_date)
2. save as esri shapefile
3. The following error appears: [[BR]]
Export to vector file failed.
Error: created field archive_date not found (OGR error:
Normalized/laundered field name: 'archive_date' to 'archive_da')
4. The created shapefile is empty
The expected truncation from archive_date to archive_da in the resulting
shapefile works (the shp, shx,dbf is created). The dbf shows the truncated
archive_da but no features are exported.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3036>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
