[QGIS-trac] [Quantum GIS] #3049: GdalTools: merging images with
different colormaps
Quantum GIS
qgis at qgis.org
Fri Sep 24 07:36:12 EDT 2010
#3049: GdalTools: merging images with different colormaps
Reporter: brushtyler | Owner: brushtyler
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Python plugins and bindings | Version:
Keywords: gdaltools, merge, colormaps | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
To mosaic colormapped images with different colormaps, you need to first
convert the images to 24bit RGB format (with pct2rgb.py).
So, in the gdal tools merge tool would be nice to
add and advice
or
add a test to see if the problem occurs and then throw a warning
Note that a similar problem occurs also with gdalbuildvrt: the resulting
colormap is the one of the first input raster. The result is a raster with
a wrong colormap in at least 50% of its extensions.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3049>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
