[QGIS-trac] Re: [Quantum GIS] #2987: Auto GCP detection library
Quantum GIS
qgis at qgis.org
Tue Sep 28 11:47:55 EDT 2010
Reporter: jamesm6162 | Owner: timlinux
Type: patch | Status: assigned
Priority: minor: annoyance | Milestone: Version 1.6.0
Component: C++ Plugins | Version: Trunk
Keywords: | Platform_version:
Platform: Debian | Must_fix: No
Status_info: 0 |
Comment(by timlinux):
A couple more comments:
- please remember the last used directory so opening rasters doesnt
require so much navigation through the file system
- for the selection of CRS, please follow the 'principle of least
surprise' and use the existing one in QGIS - its available via the python
api too.
- the processing seems to write temporary files into the image directory -
it would probably be neater to use the system /tmp directory - Qt will
give you in a cross platform manner - see QString QDir::tempPath ()
- On further testing I am getting a crash - see stack trace below:
Crash:
[Thread 0x7fffbffff710 (LWP 9076) exited]
Debug: QgsProjectionManager::setProjectionInformation - Could not find
specified projections.
Debug: qgsautogcpmanager.cpp: (QgsAutoGCPManager::extractControlPoints())
Starting Control Point Extraction
Debug: Analyzer Starting GCP extraction
Debug: Levels: 5
Features detected: 103132
Debug: Dividing image into 7 X 7 grids
Debug: Extracting GCP Chips
Debug: Levels: 5
Features detected: 55788
Debug: Dividing image into 1001 X 1001 grids
Program received signal SIGSEGV, Segmentation fault.
0x00007fffd3731d96 in QList<QgsGCP*>::detach (this=0x19ebc580) at
/usr/include/qt4/QtCore/qlist.h:122
122 inline void detach() { if (d->ref != 1) detach_helper(); }
(gdb) bt
#0 0x00007fffd3731d96 in QList<QgsGCP*>::detach (this=0x19ebc580) at
#1 0x00007fffd3731947 in QList<QgsGCP*>::append (this=0x19ebc580,
t=@0x12859818) at /usr/include/qt4/QtCore/qlist.h:468
#2 0x00007fffd350fbc1 in QList<QgsGCP*>::push_back (this=0x19ebc580,
t=@0x12859818) at /usr/include/qt4/QtCore/qlist.h:277
#3 0x00007fffd350f048 in QgsImageAnalyzer::QgsGrid::fillGrid
(this=0x102ba660, gcpSet=0x4294010) at
/home/timlinux/dev/cpp/qgis/src/autogcp/qgsimageanalyzer.cpp:505
#4 0x00007fffd350d4fd in QgsImageAnalyzer::matchGcps (this=0x10c8fb0,
gcpSet=0x490f990) at
/home/timlinux/dev/cpp/qgis/src/autogcp/qgsimageanalyzer.cpp:121
#5 0x00007fffd3507502 in QgsAutoGCPManager::matchControlPoints
(this=0x4c0d710) at
/home/timlinux/dev/cpp/qgis/src/autogcp/qgsautogcpmanager.cpp:119
#6 0x00007fffd373b022 in meth_QgsAutoGCPManager_matchControlPoints
(sipSelf=<QgsAutoGCPManager at remote 0x4302c88>, sipArgs=()) at
sipautogcppart3.cpp:1281
#7 0x00007fffd67fc030 in call_function (f=
Frame 0x7b1afd0, for file
/home/timlinux/.qgis/python/plugins/autogcp/autogcpguibase.py, line 1010,
in matchGcps (self=<Ui_MainWindow(dockWidgetContents_2=<QWidget at remote
0x42fca68>, dockWidgetContents_3=<QWidget at remote 0x4301160>,
rawMapCanvas=<QgsMapCanvas at remote 0x4301380>, gcpRawHighlight=[],
actionTest1=<QAction at remote 0x4302738>, menuSettings=<QMenu at remote
0x421ae20>, actionTest2=<QAction at remote 0x4302848>,
actionAbout=<QAction at remote 0x4301d98>, menubar=<QMenuBar at remote
0x421ab78>, gcpListSrcY=[<QTableWidgetItem at remote 0x430c5a0>,
<QTableWidgetItem at remote 0x430ca68>, <QTableWidgetItem at remote
0x430cf30>, <QTableWidgetItem at remote 0x430d490>, <QTableWidgetItem at
remote 0x430d958>, <QTableWidgetItem at remote 0x430de20>,
<QTableWidgetItem at remote 0x430e380>, <QTableWidgetItem at remote
0x430e848>, <QTableWidgetItem at remote 0x430ed10>, <QTableWidgetItem at
remote 0x430f270>, <QTableWidgetItem at remote 0x430f738>,
<QTableWidgetItem at remote 0x430fc00>, <QTableWidget...(truncated),
throwflag=<value optimized out>) at ../Python/ceval.c:3750
#8 PyEval_EvalFrameEx (f=
throwflag=<value optimized out>) at ../Python/ceval.c:2412
#9 0x00007fffd67fdd60 in PyEval_EvalCodeEx (co=0x24727b0, globals=<value
optimized out>, locals=<value optimized out>, args=0x1, argcount=<value
optimized out>,
kws=<value optimized out>, kwcount=0, defs=0x0, defcount=0,
closure=0x0) at ../Python/ceval.c:3000
#10 0x00007fffd6783d60 in function_call (func=<function at remote
0x248b488>, arg=
(<Ui_MainWindow(dockWidgetContents_2=<QWidget at remote 0x42fca68>,
<QTableWidgetItem at remote 0x430fc00>, <QTableWidgetItem at remote
0x4310160>, <QTableWidgetItem at remote 0x4310628>, <QTableWidgetItem at
remote 0x4310af0>, <QTableWidg...(truncated), kw=0x0) at
../Objects/funcobject.c:524
#11 0x00007fffd67562e3 in PyObject_Call (func=<function at remote
0x248b488>, arg=Traceback (most recent call last):
File "/usr/lib/debug/usr/lib/libpython2.6.so.1.0-gdb.py", line 1054, in
to_string
pyop = PyObjectPtr.from_pyobject_ptr(self.gdbval)
File "/usr/lib/debug/usr/lib/libpython2.6.so.1.0-gdb.py", line 343, in
from_pyobject_ptr
cls = cls.subclass_from_type(p.type())
File "/usr/lib/debug/usr/lib/libpython2.6.so.1.0-gdb.py", line 288, in
subclass_from_type
tp_name = t.field('tp_name').string()
File "/usr/lib/python2.6/encodings/utf_8.py", line 16, in decode
return codecs.utf_8_decode(input, errors, True)
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2987#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
