[QGIS-trac] [Quantum GIS] #3068: Projection information – some handbook or more info in QGIS
Quantum GIS
qgis at qgis.org
Thu Sep 30 08:38:34 EDT 2010
Reporter: jhelebrant | Owner: dassau
Type: enhancement | Status: new
Priority: minor: annoyance | Milestone: Version 1.6.0
Component: Documentation and Help | Version:
Keywords: projection, information | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
I had a small problem related with projection. I knew, that I should
convert my data in WGS84 to S-42 (Pulkovo 1942) for some reason (use with
some exotic software) but in QGIS I found a lot of "Pulkovo" projection
and did not know which one to use for my area (Czech Republic). I did not
have any internet connection available but luckily remembered, that in
Kosmo I saw some info about area used for particular projections and later
found there which "Pulkovo" is determined for Czech Republic. So this
takes me to the idea, that it would be nice to have similar info also in
QGIS (could be solved as "bubble" help) or if there is any document or app
where is possible to find this information.
The possibility to list projections used for selected area would be also
nice, but I cannot have everything I want :-)
What do you think?
PS: as an inspiration I attached two screenshots of Kosmo layer projection
dialog where you can see additional information for each projection.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3068>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
