[QGIS-trac] [Quantum GIS] #3395: Field Calculator Integer
Conversion Errror
Quantum GIS
qgis at qgis.org
Thu Jan 6 09:00:32 EST 2011
#3395: Field Calculator Integer Conversion Errror
Reporter: alexckp | Owner: jef
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: Vectors | Version: Trunk
Keywords: | Platform_version:
Platform: Windows | Must_fix: No
Status_info: 0 |
I tried to use FC to extract an integer number using the following
formula:
(SURV_BRG * 1000) - to int (to int(SURV_BRG * 100) * 10)
If the number is 62.233, the above formula will correctly return the
number 3. However, when I encounter certain numbers, e.g. the number 65.1,
the result is 9.99999999999272 instead of 0. I think this has to do with
the to int function not returning a true integer and would appreciate if
this problem could be solved.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3395>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
