[QGIS-trac] [Quantum GIS] #3420: QgsMapCanvas not rendering raster
layers in QGIS 1.7
Quantum GIS
qgis at qgis.org
Tue Jan 18 04:45:42 EST 2011
#3420: QgsMapCanvas not rendering raster layers in QGIS 1.7
Reporter: goocreations | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: MapCanvas | Version: Trunk
Keywords: QgsMapCanvas, rendering, raster | Platform_version:
Platform: Debian | Must_fix: No
Status_info: 0 |
I've found a problem when using the QgsMapCanvas in new version of
QGIS(1.7) which is not present in the previous version.
When using QgsMapCanvas in Python like this:
layer = QgsRasterLayer(filePath, fileInfo.completeBaseName())
mapRegistry = QgsMapLayerRegistry.instance().addMapLayer(layer, False)
layerSet = []
mapCanvasLayer = QgsMapCanvasLayer(layer, True)
layerSet.append(mapCanvasLayer)
self.canvas.setExtent(layer.extent())
self.canvas.enableAntiAliasing(True)
self.canvas.freeze(False)
self.canvas.setLayerSet(layerSet)
self.canvas.setVisible(True)
self.canvas.refresh()
The debug console says the raster was render without issues, the extent
was set correctly, but the raster is not showing on the canvas (MirrorMap
python plugin has the problem too).
After working through the C++ source code of QgsMapCanvas, I've noticed
that most of the resizeEvent's code is now in the paintEvent. For some
reason repaint is not called once the canvas resizes, hence the code
(previously in the resiveEvent) is never executed. The important part of
the code is:
mMap->resize( QSize( width, height ) );
which when called renders the raster correctly. I've adapted the python
code of my plug-in as follows:
layerSet = []
width = self.canvas.size().width() #NEW CODE
height = self.canvas.size().height() #NEW CODE
self.canvas.map().resize( QSize( width, height ) ) #NEW CODE
Every time I add a raster layer to the canvas, I have to manually resize
the map of the canvas.
I'm not sure if this is a bug, or if it has to be this way. Is there any
other or better way doing this?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3420>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
