[QGIS-trac] [Quantum GIS] #3429: Can't chose edit widget "Enumeration" for empty postgres tables
Quantum GIS qgis at qgis.org
Fri Jan 21 15:21:39 EST 2011
   Reporter:  anitagraser                       |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Digitising                        |            Version:  Trunk
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
 It's not possible to chose an edit widget of type "Enumeration" as long as
 the underlying table is empty.
 You can test using:
 CREATE TYPE rainbow AS ENUM ('red', 'orange', 'yellow', 'green', 'blue',
 'purple');
 CREATE TABLE teste
 rain rainbow,
 the_geom geometry
 When one line is added, everything works as expected.
 According to user cremat0rio on the related forum topic
 (http://forum.qgis.org/viewtopic.php?f=2&t=7834) it's possible to use the
 following line to populate the enum widget:
 SELECT enum_range(null::rainbow);
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3429>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
