[QGIS-trac] [Quantum GIS] #3439: QGIS crashes when reshaping
invalid polygon geometry
Quantum GIS
qgis at qgis.org
Tue Jan 25 09:16:45 EST 2011
#3439: QGIS crashes when reshaping invalid polygon geometry
Reporter: marisn | Owner: jef
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.7.0
Component: Vectors | Version: Trunk
Keywords: | Platform_version:
Platform: Gentoo | Must_fix: No
Status_info: 0 |
GEOS 3.2.2 QGIS r15075
Steps to reproduce:
* draw self intersecting polygon;
* use reshape too to reshape it:
Debug: /home/maris/soft/qgis_trunk/src/providers/ogr/qgsogrprovider.cpp:
591: (select) Setting spatial filter using POLYGON((556162.68083173
6356447.94617169, 556162.68083173 6357221.35032134, 557111.30935904
6357221.35032134, 557111.30935904 6356447.94617169, 556162.68083173
6356447.94617169))
ERROR 1: TopologyException: found non-noded intersection between
LINESTRING (556163 6.35744e+06, 555613 6.35629e+06) and LINESTRING (556271
6.35654e+06, 555299 6.35676e+06) at 555784 6.35665e+06
Program received signal SIGSEGV, Segmentation fault.
GEOSGeomTypeId_r (extHandle=0xb21c30, g1=0x0) at geos_ts_c.cpp:1296
1296 geos_ts_c.cpp: No such file or directory.
in geos_ts_c.cpp
(gdb) bt
#0 GEOSGeomTypeId_r (extHandle=0xb21c30, g1=0x0) at geos_ts_c.cpp:1296
#1 0x00007ffff716fff5 in QgsGeometry::reshapeLine (line=0x25af600,
reshapeLineGeos=0x2505cb0)
at /home/maris/soft/qgis_trunk/src/core/qgsgeometry.cpp:5179
#2 0x00007ffff717086e in QgsGeometry::reshapePolygon (polygon=0x25b6d10,
at /home/maris/soft/qgis_trunk/src/core/qgsgeometry.cpp:5087
#3 0x00007ffff7170c2d in QgsGeometry::reshapeGeometry (this=0xcd31d0,
reshapeWithLine=...)
at /home/maris/soft/qgis_trunk/src/core/qgsgeometry.cpp:3280
#4 0x00000000005a514e in QgsMapToolReshape::canvasReleaseEvent
(this=0xfbc990, e=<value optimized out>)
at /home/maris/soft/qgis_trunk/src/app/qgsmaptoolreshape.cpp:104
#5 0x00007ffff6d28cc8 in QgsMapCanvas::mouseReleaseEvent (this=0xc4f300,
at /home/maris/soft/qgis_trunk/src/gui/qgsmapcanvas.cpp:921
#6 0x00007ffff55f0cbd in QWidget::event (this=0xc4f300,
event=0x7fffffffc510) at kernel/qwidget.cpp:8200
#7 0x00007ffff59c4db4 in QFrame::event (this=0xc4f300, e=0x7fffffffc510)
at widgets/qframe.cpp:557
#8 0x00007ffff5c397d1 in QGraphicsView::viewportEvent (this=0xc4f300,
at graphicsview/qgraphicsview.cpp:2864
#9 0x00007ffff624c2e9 in
QCoreApplicationPrivate::sendThroughObjectEventFilters (this=<value
optimized out>,
receiver=0xc45930, event=0x7fffffffc510) at
kernel/qcoreapplication.cpp:847
#10 0x00007ffff5592b0c in QApplicationPrivate::notify_helper
(this=0xb58b10, receiver=0xc45930,
e=0x7fffffffc510) at kernel/qapplication.cpp:4441
#11 0x00007ffff55987eb in QApplication::notify (this=0x7fffffffd360,
receiver=0xc45930, e=0x7fffffffc510)
at kernel/qapplication.cpp:4006
#12 0x00007ffff714bae6 in QgsApplication::notify (this=<value optimized
out>, receiver=<value optimized out>,
event=<value optimized out>) at
/home/maris/soft/qgis_trunk/src/core/qgsapplication.cpp:88
#13 0x00007ffff624c94e in QCoreApplication::notifyInternal
(this=0x7fffffffd360, receiver=0xc45930,
event=0x7fffffffc510) at kernel/qcoreapplication.cpp:732
#14 0x00007ffff5596c9c in sendEvent (receiver=0xc45930,
event=0x7fffffffc510, alienWidget=0xc45930,
nativeWidget=0xd279f0, buttonDown=<value optimized out>,
lastMouseReceiver=<value optimized out>,
spontaneous=true) at
../../include/QtCore/../../src/corelib/kernel/qcoreapplication.h:215
#15 QApplicationPrivate::sendMouseEvent (receiver=0xc45930,
Depending on self intersecting polygon shape, it migh also show "unknown
exception" error. After that, it's impossible to stop reshape tool - ESC
doesn't work, right click just gives exception warning. Only way out is to
BACKSPACE all nodes till reshaping line contains no more nodes.
591: (select) Setting spatial filter using POLYGON((555697.42989796
6358290.82324704, 555697.42989796 6359396.54949225, 556446.66516793
6359396.54949225, 556446.66516793 6358290.82324704, 555697.42989796
6358290.82324704))
Debug: /home/maris/soft/qgis_trunk/src/core/qgsgeometry.cpp: 93:
(throwGEOSException) GEOS exception encountered: TopologyException: found
non-noded intersection between LINESTRING (556107 6.35923e+06, 555867
6.35867e+06) and LINESTRING (556374 6.35902e+06, 556049 6.35918e+06) at
556078 6.35916e+06
6358290.82324704, 555697.42989796 6359783.25156708, 556446.66516793
6359783.25156708, 556446.66516793 6358290.82324704, 555697.42989796
6358290.82324704))
556078 6.35916e+06
Debug: /home/maris/soft/qgis_trunk/src/core/qgsgeometry.cpp: 6496:
(validatePolyline) līnijas 0 segmenti 0 un 4 krustojas 556274.812174,
6358657.66189
(validatePolyline) līnijas 0 segmenti 2 un 4 krustojas 556072.148796,
6359200.42703
6358290.82324704))
non-noded intersection between LINESTRING (556082 6.35917e+06, 555867
6.35867e+06) and LINESTRING (556087 6.35916e+06, 556049 6.35918e+06) at
556078 6.35916e+06
When reshaping self intersecting line, QGIS just fails silently (with
debug in console). Same should happen on incorrect polygons.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3439>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
