[QGIS-trac] [Quantum GIS] #3453: Postgis layer load starts out with
unnecessarily expensive query
Quantum GIS
qgis at qgis.org
Sun Jan 30 11:22:29 EST 2011
#3453: Postgis layer load starts out with unnecessarily expensive query
Reporter: arencambre | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: Data Provider | Version: 1.6.0
Keywords: | Platform_version: 7
Platform: Debian | Must_fix: No
Status_info: 0 |
Postgis layer loads start out with this query:
{{{ select distinct case when geometrytype("the_geom") IN
('POINT','MULTIPOINT') THEN 'POINT' when geometrytype("the_geom") IN
('LINESTRING','MULTILINESTRING') THEN 'LINESTRING' when
geometrytype("the_geom") IN ('POLYGON','MULTIPOLYGON') THEN 'POLYGON' end
from [databaseGoesHere] }}}
I think this is needlessly expensive for my 12,000,000 row Postgis dataset
for two reasons:
* DISTINCT isn't necessary because my dataset has no duplicates even
though some rows may have identical locations. Do GIS datasets routinely
have duplicate data? At least let me override DISTINCT before loading
large datasets. I am now worried that other datasets may have had objects
missed that had identical locations.
* Not sure why each geometry object is being checked for geometry type.
QGIS knows the geometry type before the Postgis layer is even loaded
thanks to the '''geometry_columns''' table.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3453>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
