[QGIS-trac] [Quantum GIS] #3860: Crash when setting vector area
 class transparency
    Quantum GIS
    qgis at qgis.org
    Wed Jun  1 04:05:24 EDT 2011
#3860: Crash when setting vector area class transparency
   Reporter:  marisn                                     |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.7.0
  Component:  Symbology                                  |            Version:  Trunk
   Keywords:                                             |   Platform_version:
   Platform:  Gentoo                                     |           Must_fix:  No
Status_info:  0                                          |
 It happens time to time. One needs to have multiple layers in project. I
 had some vectors and some WMS layers. Changed transparency for one of
 vector area symbol classes in new symbology, pressed Apply to see results
 -> crash.
 ~AMD64 Gentoo with Qt 4.7.3.
 #0  0x00007ffff6031cb0 in vtable for QX11PixmapData () from
 /usr/lib64/qt4/libQtGui.so.4
 #1  0x00007ffff39251c3 in __dynamic_cast () from /usr/lib/gcc/x86_64-pc-
 linux-gnu/4.5.2/libstdc++.so.6
 #2  0x00000000006b131f in QgsLegend::currentLegendLayer (this=<value
 optimized out>) at
 /home/maris/soft/qgis_trunk/src/app/legend/qgslegend.cpp:684
 #3  0x00000000006b1389 in QgsLegend::currentLayer (this=<value optimized
 out>) at /home/maris/soft/qgis_trunk/src/app/legend/qgslegend.cpp:706
 #4  0x00000000006b13c6 in QgsLegend::handleCurrentItemChanged
 (this=0xd85d30, current=<value optimized out>, previous=<value optimized
 out>)
     at /home/maris/soft/qgis_trunk/src/app/legend/qgslegend.cpp:141
 #5  0x000000000072de75 in QgsLegend::qt_metacall (this=0xd85d30,
 _c=QMetaObject::InvokeMetaMethod, _id=37, _a=0x7fffffff9290)
     at
 /home/maris/soft/qgis_trunk/build/src/app/legend/moc_qgslegend.cxx:192
 #6  0x00007ffff61de617 in QMetaObject::activate (sender=0xd85d30, m=<value
 optimized out>, local_signal_index=<value optimized out>,
 argv=0x7fffffff9290)
     at kernel/qobject.cpp:3278
 #7  0x00007ffff5b1667b in QTreeWidget::currentItemChanged (this=<value
 optimized out>, _t1=0x3231fa0, _t2=0x0)
     at .moc/release-shared/moc_qtreewidget.cpp:256
 #8  0x00007ffff5b1edfd in QTreeWidget::qt_metacall (this=0xd85d30,
 _c=QMetaObject::InvokeMetaMethod, _id=23, _a=0x7fffffff94e0)
     at .moc/release-shared/moc_qtreewidget.cpp:157
 #9  0x000000000072d839 in QgsLegend::qt_metacall (this=0xd85d30,
 _c=QMetaObject::InvokeMetaMethod, _id=<value optimized out>,
 _a=0x7fffffff94e0)
     at
 /home/maris/soft/qgis_trunk/build/src/app/legend/moc_qgslegend.cxx:142
 #10 0x00007ffff61de617 in QMetaObject::activate (sender=0xdac7a0, m=<value
 argv=0x7fffffff94e0)
 #11 0x00007ffff5af42ba in QItemSelectionModel::currentChanged (this=<value
 optimized out>, _t1=<value optimized out>, _t2=<value optimized out>)
     at .moc/release-shared/moc_qitemselectionmodel.cpp:159
 #12 0x00007ffff5af43b2 in QItemSelectionModel::setCurrentIndex
 (this=0xdac7a0, index=..., command=<value optimized out>)
     at itemviews/qitemselectionmodel.cpp:1169
 #13 0x00007ffff5a9cbf3 in QAbstractItemView::setCurrentIndex
 (this=0xd85d30, index=...) at itemviews/qabstractitemview.cpp:1016
 #14 0x00000000006b2a6a in QgsLegend::refreshLayerSymbology (this=0xd85d30,
 key=..., expandItem=false)
     at /home/maris/soft/qgis_trunk/src/app/legend/qgslegend.cpp:1576
 #15 0x000000000072d9de in QgsLegend::qt_metacall (this=0xd85d30,
 _c=QMetaObject::InvokeMetaMethod, _id=5, _a=<value optimized out>)
     at
 /home/maris/soft/qgis_trunk/build/src/app/legend/moc_qgslegend.cxx:152
 #16 0x00007ffff61de617 in QMetaObject::activate (sender=0x5502c80,
 m=<value optimized out>, local_signal_index=<value optimized out>,
 argv=0x7fffffff98f0)
 #17 0x000000000072aeb1 in QgsVectorLayerProperties::refreshLegend
 (this=<value optimized out>, _t1=<value optimized out>, _t2=false)
     at
 /home/maris/soft/qgis_trunk/build/src/app/moc_qgsvectorlayerproperties.cxx:203
 #18 0x0000000000655c23 in QgsVectorLayerProperties::apply (this=0x5502c80)
 at /home/maris/soft/qgis_trunk/src/app/qgsvectorlayerproperties.cpp:790
 #19 0x000000000072b06d in QgsVectorLayerProperties::qt_metacall
 (this=0x5502c80, _c=QMetaObject::InvokeMetaMethod, _id=8,
 _a=0x7fffffff9ed0)
     at
 /home/maris/soft/qgis_trunk/build/src/app/moc_qgsvectorlayerproperties.cxx:159
 #20 0x00007ffff61de617 in QMetaObject::activate (sender=0x552ce60,
 argv=0x7fffffff9ed0)
 #21 0x00007ffff5c03f62 in QAbstractButton::clicked (this=<value optimized
 out>, _t1=false) at .moc/release-shared/moc_qabstractbutton.cpp:206
 #22 0x00007ffff594c28b in QAbstractButtonPrivate::emitClicked (this=<value
 optimized out>) at widgets/qabstractbutton.cpp:546
 #23 0x00007ffff594d84b in QAbstractButtonPrivate::click (this=0x20513a0)
 at widgets/qabstractbutton.cpp:539
 #24 0x00007ffff594dabc in QAbstractButton::mouseReleaseEvent
 (this=0x552ce60, e=0x7fffffffaa30) at widgets/qabstractbutton.cpp:1121
 #25 0x00007ffff560450b in QWidget::event (this=0x552ce60,
 event=0x7fffffffaa30) at kernel/qwidget.cpp:8259
 #26 0x00007ffff55b2c34 in QApplicationPrivate::notify_helper
 (this=0xb51d50, receiver=0x552ce60, e=0x7fffffffaa30) at
 kernel/qapplication.cpp:4462
 #27 0x00007ffff55b8222 in QApplication::notify (this=<value optimized
 out>, receiver=0x552ce60, e=0x7fffffffaa30) at
 kernel/qapplication.cpp:4023
 #28 0x00007ffff711f36e in QgsApplication::notify (this=0x7fffffffd210,
 receiver=0x552ce60, event=0x7fffffffaa30)
     at /home/maris/soft/qgis_trunk/src/core/qgsapplication.cpp:124
 #29 0x00007ffff61c9f3b in QCoreApplication::notifyInternal
 (this=0x7fffffffd210, receiver=0x552ce60, event=0x7fffffffaa30)
     at kernel/qcoreapplication.cpp:731
 #30 0x00007ffff55b3c45 in sendEvent (receiver=0x552ce60,
 event=0x7fffffffaa30, alienWidget=0x552ce60, nativeWidget=0x5502c80,
 buttonDown=0x7ffff6065118,
     lastMouseReceiver=..., spontaneous=true) at
 ../../include/QtCore/../../src/corelib/kernel/qcoreapplication.h:215
 #31 QApplicationPrivate::sendMouseEvent (receiver=0x552ce60,
     buttonDown=0x7ffff6065118, lastMouseReceiver=..., spontaneous=true) at
 kernel/qapplication.cpp:3122
 #32 0x00007ffff5632748 in QETWidget::translateMouseEvent (this=0x5502c80,
 event=<value optimized out>) at kernel/qapplication_x11.cpp:4461
 #33 0x00007ffff5630e09 in QApplication::x11ProcessEvent
 (this=0x7fffffffd210, event=0x7fffffffb1e0) at
 kernel/qapplication_x11.cpp:3587
 #34 0x00007ffff5658452 in x11EventSourceDispatch (s=0xb56730, callback=0,
 user_data=0x0) at kernel/qguieventdispatcher_glib.cpp:146
 #35 0x00007ffff211f3ae in g_main_dispatch (context=0xb554e0) at
 gmain.c:2440
 #36 g_main_context_dispatch (context=0xb554e0) at gmain.c:3013
 #37 0x00007ffff211fb98 in g_main_context_iterate (context=0xb554e0,
 block=1, dispatch=1, self=<value optimized out>) at gmain.c:3091
 #38 0x00007ffff211fe2d in g_main_context_iteration (context=0xb554e0,
 may_block=1) at gmain.c:3154
 #39 0x00007ffff61f4e1f in QEventDispatcherGlib::processEvents
 (this=0xb52c60, flags=<value optimized out>) at
 kernel/qeventdispatcher_glib.cpp:422
 #40 0x00007ffff56580fe in QGuiEventDispatcherGlib::processEvents
 (this=<value optimized out>, flags=<value optimized out>)
     at kernel/qguieventdispatcher_glib.cpp:204
 #41 0x00007ffff61c9302 in QEventLoop::processEvents (this=<value optimized
 out>, flags=...) at kernel/qeventloop.cpp:149
 #42 0x00007ffff61c9544 in QEventLoop::exec (this=0x7fffffffb4e0,
 flags=...) at kernel/qeventloop.cpp:201
 #43 0x00007ffff5a4bb7e in QDialog::exec (this=0x5502c80) at
 dialogs/qdialog.cpp:552
 #44 0x00000000004f5cb8 in QgisApp::showLayerProperties (this=0xc8a360,
 ml=<value optimized out>) at
 /home/maris/soft/qgis_trunk/src/app/qgisapp.cpp:6546
 #45 0x00000000006b0672 in QgsLegend::mouseDoubleClickEvent (this=<value
 optimized out>, e=<value optimized out>)
     at /home/maris/soft/qgis_trunk/src/app/legend/qgslegend.cpp:543
 #46 0x00007ffff5604525 in QWidget::event (this=0xd85d30,
 event=0x7fffffffc540) at kernel/qwidget.cpp:8263
 #47 0x00007ffff598ed16 in QFrame::event (this=0xd85d30, e=0x7fffffffc540)
 at widgets/qframe.cpp:557
 #48 0x00007ffff5a9f053 in QAbstractItemView::viewportEvent (this=0xd85d30,
 event=0x7fffffffc540) at itemviews/qabstractitemview.cpp:1628
 #49 0x00007ffff5ae3b75 in QTreeView::viewportEvent (this=0xd85d30,
 event=0x7fffffffc540) at itemviews/qtreeview.cpp:1256
 #50 0x00007ffff61ca0b6 in
 QCoreApplicationPrivate::sendThroughObjectEventFilters (this=<value
 optimized out>, receiver=0xdb30d0, event=0x7fffffffc540)
     at kernel/qcoreapplication.cpp:846
 #51 0x00007ffff55b2c01 in QApplicationPrivate::notify_helper
 (this=0xb51d50, receiver=0xdb30d0, e=0x7fffffffc540) at
 kernel/qapplication.cpp:4458
 #52 0x00007ffff55b8222 in QApplication::notify (this=<value optimized
 out>, receiver=0xdb30d0, e=0x7fffffffc540) at kernel/qapplication.cpp:4023
 #53 0x00007ffff711f36e in QgsApplication::notify (this=0x7fffffffd210,
 #54 0x00007ffff61c9f3b in QCoreApplication::notifyInternal
 (this=0x7fffffffd210, receiver=0xdb30d0, event=0x7fffffffc540) at
 #55 0x00007ffff55b3c45 in sendEvent (receiver=0xdb30d0,
 event=0x7fffffffc540, alienWidget=0xdb30d0, nativeWidget=0xee7160,
 #56 QApplicationPrivate::sendMouseEvent (receiver=0xdb30d0,
 #57 0x00007ffff5632748 in QETWidget::translateMouseEvent (this=0xee7160,
 #58 0x00007ffff5630e09 in QApplication::x11ProcessEvent
 (this=0x7fffffffd210, event=0x7fffffffccf0) at
 #59 0x00007ffff5658452 in x11EventSourceDispatch (s=0xb56730, callback=0,
 #60 0x00007ffff211f3ae in g_main_dispatch (context=0xb554e0) at
 gmain.c:2440
 #61 g_main_context_dispatch (context=0xb554e0) at gmain.c:3013
 #62 0x00007ffff211fb98 in g_main_context_iterate (context=0xb554e0,
 #63 0x00007ffff211fe2d in g_main_context_iteration (context=0xb554e0,
 #64 0x00007ffff61f4e1f in QEventDispatcherGlib::processEvents
 #65 0x00007ffff56580fe in QGuiEventDispatcherGlib::processEvents
 #66 0x00007ffff61c9302 in QEventLoop::processEvents (this=<value optimized
 #67 0x00007ffff61c9544 in QEventLoop::exec (this=0x7fffffffcff0,
 #68 0x00007ffff61cd9ab in QCoreApplication::exec () at
 kernel/qcoreapplication.cpp:1008
 #69 0x00000000004dfff2 in main (argc=1, argv=<value optimized out>) at
 /home/maris/soft/qgis_trunk/src/app/main.cpp:764
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3860>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac
